Archive management
When i try to check the archive configuration od hte device it give an error message saying CM0003:Version 2 does nto exist in archive device 10.X.X.X version may have been deleted.
1 REPLY
Re: Archive management
This usually indicates a bad archive for the given device (e.g. someone deleted the underlying config file from the file system). If you delete the device from RME, then re-manage it, your archiving should work again.
119
