Community Member
AS 5350 discovered as Unknown device
After device discovery in LMS 2.3, the RAS (AS5350) is shown as an unknown device. Can anyone help me on this .
Thanks and regards
Rajesh
1 ACCEPTED SOLUTION
Re: AS 5350 discovered as Unknown device
Okay, this is an AS5350XM which is not supported until LMS 2.6 SP1. Therefore, you need to upgrade to CS 3.0.6, RME 4.0.6, and Campus 4.0.10 to get support.
There is no LMS 2.3. Please double-check the version, and provide exactly where you see the device showing as unknown.
Community Member
hi Clarke
ooops....It is 2.6.that was a typo :)
Actually Iam using LMS 2.6 and VMS 2.3
rgds
Rajesh
Are they installed on the same server?
Community Member
Hi Clarke,
Both are running on different servers. LMS with Win 2003R2 OS and VMS in Win 2000.
All my 7200, 3500, 2900 series are being discovered properly , but the 5300 devices are being discovered as unknown devices.
rgds
rajesh
Okay, good. the two cannot be installed on the same server, and doing so would definitely have messed things up. You still have not said exactly where these 5300 devices are showing as unknown. A screenshot would be helpful.
Community Member
Hi clarke..
Iam sending you a some screen shots. Hope it helps.
thaks and rgds
Rajesh
Community Member
Hi clarke..
Thaks for the info
rgds
Rajesh
149
