AS 5350 OID's
Hello everyone who is reading this thread.
I need to monitor E1-channel load("sh isdn status" command - active layer 3 calls). Found the following OID:
1.3.6.1.4.1.9.10.19.1.1.9.1.3.X.Y(X-slot,Y-port). Have 2 AS installed:
1st: Board Hardware Version 2.6,Board Revision C1 with E1 2 PRI
2nd: Board Hardware Version 2.7,Board Revision B0 E1 4 PRI).
On the first AS I'm getting the correct Counter value, on the other AS i'm getting decreasing in time large number.Should I make a TAC request? (couldn't find with snmpwalk even close value I need)
Thank in advance.
1 REPLY
Re: AS 5350 OID's
Forget to add IOS c5350-is-mz.124-11.T1.bin
195
