05-13-2010 12:59 PM
I have to set up my ASA having the failover lince to connect to another 1 , in the same way we can connect PIC in failover mode. Please send me a link and the best possible configs.
Also any information regarding this
05-13-2010 01:08 PM
Hi Imran,
Here is a reference link for the Failover Active/Standby configuration:
Hope the links helps!
Sai
05-17-2010 11:08 AM
Attached is my diagram let me know if this looks ok, with the Active/Standby configs you have sent.
I have 2 WAN IPs from the ISP & want to configure HSRP between switches let me know if this looks good.
Also how many interfaces on ASA side will be used for failover , as i have to connect 1 interface to WAN 2 interfaces to LAN 1 for each switch.
