05-23-2012 12:03 AM
Hi ,
How can i store the logs of ASA firewall to an external desktop or a server ?
I need to report these logs regulary to the customer.
Solved! Go to Solution.
02-11-2014 03:55 PM
Try with just " / " in the path, because the filezilla already share the entire path, you just configure the asdm/asa-cli with the root path.
05-23-2012 07:14 AM
You need to have a server running a syslog daemon (or ftp server). Then configure that server's IP address as the destination for your ASA's log messages.
You can do the latter from the command line or ASDM GUI, depending on your preference. The configuration guides for the ASA tell you how step-by-step. They are all posted here.
Specifically, see this section for the setup with ASDM 6.4.
05-23-2012 10:42 PM
Thanks for the reply,
I have done the settings through ASDM but just have one confusion , what should be written in the path field
suppose the ip of my ftp server is 10.10.10.10 and i need to store the logs in a folder named LOG which is placed on the desktop of the server then what shud go in the path field ??
05-24-2012 05:29 AM
Create a user on the FTP server whose home directory is that LOG folder and then no path needs to be specified.
Alternatively, you can specifiy it as shown in the CLI configuration guide:
logging ftp-server server path username password
Example:
hostname(config)# logging ftp-server 10.1.1.1 /syslogs logsupervisor 1luvMy10gs
The above command identifies the FTP server on which you want to store log buffer content. The server argument specifies the IP address of the external FTP server. The path argument specifies the directory path on the FTP server where the log buffer data is to be saved. This path is relative to the FTP root directory. The username argument specifies a username that is valid for logging into the FTP server. The password argument indicates the password for the username specified.
05-24-2012 09:42 PM
Still no luck ...
i created a user in ftp assigned tht folder LOG as the root or home directory for it.
in ASDM i gave tha path to the server but still no luck :\
05-24-2012 10:48 PM
find in google kiwi syslog, download it and install
in asa make so
conf t
logging enable
logging timestamp
logging console debugging
logging buffered debugging
logging trap informational
logging asdm informational
logging host inside 192.168.a.b
wr
and dont forget to rate post
05-24-2012 11:43 PM
Well now i am getting somewhere , Firewall is able to communicate with the ftp server but these messages are being displayed
000069)5/25/2012 12:10:43 PM - cisco (192.168.100.1)> STOR ftp:\\192.168.x.x\Desktop\logs/LOG-2012-05-25-121337.TXT
(000069)5/25/2012 12:10:43 PM - cisco (192.168.100.1)> 550 Filename invalid
(000069)5/25/2012 12:10:43 PM - cisco (192.168.100.1)> QUIT
05-25-2012 01:17 AM
probably fw has not privilege to create file in ftp directory. check it manually.
05-25-2012 06:32 AM
I see a front slash instead of a backslash in your path preceding the filename. That may be a contributing factor.
05-27-2012 10:48 PM
i have tried changing tht too...still no success
05-28-2012 11:03 AM
You may be running into a limitation of your ftp server software. What is your ftp server software?
Have you tried a test of manually creating a file with that name and doing an FTP PUT to upload it and see if it works?
05-28-2012 09:53 PM
I am using Filezilla..
05-29-2012 04:51 PM
Have you verified manually that you can copy a file using ftp from your ASA to your server?
For example:
copy disk0:/running-config ftp://[user[:password]@]server/[path/]filename
Put in your server's IP address in place of "server".
05-30-2012 11:03 PM
yeah.. it worked
manually i am able to copy files into the root directory.
Can it be the case that the format in which the ASA saves it log files has some issue ?
02-24-2013 11:06 PM
STOR ftp://192.168.x.x/LOG-2013-02-25-122705.TXT
(000072)2/25/2013 12:33:07 PM - cisco (192.168.100.1)> 550 Filename invalid
Any help ???
