ASDM 5.2 for ASA - Unable to read configuration
Started setup for the ASA 5510 with SSM-10 module. While attempting to connect with the ASDM 5.2 I received the following "ASDM is unable to read the configuration from the ASA. Please check the configuration and your connection and then try again by clicking the Refresh Icon."
I am able to connect via the Console port without any problem, where I verified that the Management interface is Up.
What am I missing?
1 ACCEPTED SOLUTION
Re: ASDM 5.2 for ASA - Unable to read configuration
I believe it is an issue with the Java version you have installed on your workstation. For ASDM 5.2, you need Sun Java 1.6 update 7 or older... 1.6 update 10 and above don't work with that version of ASDM.
Thank You John. You are spot-on. Removed Java JRE 6 and installed Java JRE 1.5. ASDM 5.2 is working. This issue is resolved.
Suggestion for Cisco Marketing - You should include several items in your ASDM distribution CD:
1) You must advise customers to remove their current Java installation (unless the need the most current JRE for other applications) and install JRE 1.5 or older;
2) Include a copy of Java JRE 1.5 with your ASDM distribution CD
1628
