Community Member
Authentication Failure:MinorAlarm Alert
Hi All,
Does anyone know what is the meaning of the following alert:
ALERT ID = 000015Y
TIME = Fri 13-Jul-2007 03:10:29 CDT
STATUS = Cleared
SEVERITY = Informational
MANAGED OBJECT = 148.206.100.12
MANAGED OBJECT TYPE = Routers
EVENT DESCRIPTION = 148.206.100.12: Authentication Failure:MinorAlarm;
I am getting one or two of these alerts every day but I am not sure the reason that triggers it.
Re: Authentication Failure:MinorAlarm Alert
It's likely that this means there is a community string mismatch between what is being used by the polling station, and what is configured on the device.
Verify community strings match on both.
-Joe R.
Community Member
In case if we are configure SNMP v3 Credintial on both Devices . so what is missmatched.
ON ROUTER SNMP V3 config by User name and Password with MD5 Authentication same Credential on Monitoring System .
syed
355
