Authentication with TACACS+ ACS failed
I have been getting the following pop-up upon opening a new window.
"Authentication with TACACS+ ACS failed. You are in the fallback mode.
To revert to CiscoWorks Local mode, you have to run:
NMSROOT/bin/perl NMSROOT/bin/ResetLoginModule.pl.
You must have appropriate privileges on the system to run this script.
Note: NMSROOT is the product installation directory."
How do I go about configuring my TACACS+ ACS server as well as CW to avoid this?
1 REPLY
Re: Authentication with TACACS+ ACS failed
Here is a write up that was original produced by TAC that takes you step-by-step through basic LMS/ACS integration:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddd5a10/0#selected_message
This should take care of this problem for you.
326
