Webcast-Catalyst9k
Bandwidth limiting on 3560G
Hi, I would like restrict bandwidth on a specific gigabit port to 33kbps for Testing purposes ( inbound/outbound ). I believe l have to setup QOS Service and Policy Maps. Could someone please provide some assistance for me.
Thanks Simon Galloway
Re: Bandwidth limiting on 3560G
hi
In software releases earlier than Cisco IOS Release 12.2(25)SE, you can apply a policy map only to the incoming traffic on a physical port. In Cisco IOS Release 12.2(25)SE or later, you can apply a policy map to incoming traffic on a physical port or on an SVI. In Cisco IOS Release 12.2(25)SED or later, you can configure different interface-level policy maps for each class defined in the VLAN-level policy map.
do refer the below link for more info in configuring the same...
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_command_reference_chapter09186a00808781c9.html#wp1864211
regds
Hi DS,
This is what l have configured for the particular interface but it doesn't seem to be only allowing for example 56kbps.
class-map match-all Dialup
match input-interface GigabitEthernet0/44
policy-map Dialup
class Dialup
police 56000 56000 exceed-action drop
I am not sure if l need to do anything else from this config to only allow 56kbps for this particular interface.
118
