Baseline template command still not compliant after deploy
orsonjoon
In the baseline template for in this case a Catalyst 3560 access switch I entered the following command:
+ banner motd ^<NL>************************************************************************<NL>* *<NL>* *<NL>* Warning: Access for authorized personel only! *<NL>* *<NL>* Use by unauthorized persons is prohibited. *<NL>* *<NL>* *<NL>************************************************************************<NL><NL>^
When I deploy this to the switch and check the config in the switch the command is correctly entered by LMS 3.0 in the running and startup config.
When after this I run the same template compliance check, it states "not compliant" and when I check the details of the job it's telling me that this command I just deployed with the tool is not compliant.
I noticed that this is not the only command that fails after a deploy in the same way.
If anyone ran into the same problem, please share your thoughts, thanks.
Joe Clarke
Try using quotes to delimit the banner instead of ^.
That did it, thank very much!
