03-08-2010 11:33 AM
I am trying to scan complaince check on certain interfaces. I am interesting to check Ethernet and Fast ethernet interface and the interface number is 300,301 and 302. also from MLS switch Vlan 125,126 my question is how I can accomplish to add all requirments on sub mode.
here is what I did for one interface but I don't know how to add 301 and 302, if I use wildcard(*) may going to scan all300 interface I do want only from 300->302. interface [#.*Ethernet0/0.300-#] also no idea how to do for vlan . Thanks for any help
Solved! Go to Solution.
03-08-2010 11:37 AM
You can use:
interface [#.*Ethernet0/0\.30[012]#]
The same thing would work for VLANs:
interface [#Vlan12[56]#]
03-08-2010 08:57 PM
You will need to create one commandlet per interface to ensure that the right sub-interface has the right access-group applied.
03-08-2010 11:37 AM
You can use:
03-08-2010 11:39 AM
awesome!! thank you so very much!
03-08-2010 03:10 PM
Hi Joe, I got some difficulties while to achive my goal, actually each interface has different access list rule, so do I need to create separate template for each interface to scan for compliance?or Can I do one template to check each interface for different value(access_list). my objective is to check these interfaces properly configured on all routers. here is example to show you what's looks like.
interface GigabitEthernet0/0.300
ip address XXXXXXXX
encapsulation dot1Q 200
ip access-group eng_IN in
interface GigabitEthernet0/0.301
encapsulation dot1Q 201
ip address XXXXXXXX ip
access-group market_IN in
interface GigabitEthernet0/0.302
encapsulation dot1Q 202
ip address XXXXXXXXX
ip access-group lab_IN in
once again thank you.
03-08-2010 08:57 PM
