Community Member
BBSM 5.3 Port hopping issue
Greetings to all.
I have a question about enabling port hopping on my bbsm server.
Basically, i want to enable it in order to disconnect users after a given period of time. For some reason, packet inactivity does not work.
I enabled port hoppping in both ports and antennas and set the port hopping time to 5 minutes but in testing the user is not disconnected and in the transaction history there is nothing in relevance to port hopping.
1. Do i need to do something else?
2. Is there a way to troubleshoot what exactly is going on (something like a log)?
3. Maybe it has something to do with packet inactivity, which as i stated, also does not work?
I checked my hardware, and both choices are supported.
Thanks in advance.
1 REPLY
Silver
Re: BBSM 5.3 Port hopping issue
Here is the URL for the configuration of the Cisco BBSM 5.3 and also follow the Configuring the Port Hop Delay which will help you :
http://www.cisco.com/en/US/docs/net_mgmt/cisco_building_broadband_service_manager/5.3/software_configuration/guide/cfg53_20.html
99
