Community Member
BBSM 5.3
Hi guys, I have a problem with the BBSM 5.3 Server. The administrator creates access codes by duration but sometimes a few ACs get blocked since their creation then the end user cannot use them eventhough the reporting page shows them intac and active, I opened a case to the TAC because I suspect it is bug or something wrong with the BBSM, has any one had experienced something like that ?? Thanks a lot
1 REPLY
Bronze
Re: BBSM 5.3
check out the following link for information on access code access policy, hope this helps :
http://www.cisco.com/en/US/products/sw/netmgtsw/ps533/products_user_guide_chapter09186a0080205ab7.html#wp1037603
93
