Community Member
BBSM 5.3SP2 and Network Elements
When I create an Access Point there are 8 ports available.
Does anyone know if there is a way to increase the number of ports per Access Point or to Configure the BBSM to allow more than 8 clients per Access Point.
Using a null switch is not an option.
reload in 25 years
Community Member
Re: BBSM 5.3SP2 and Network Elements
Even with 8 ports there is no real limit to the number of actual connections through the AP
reload in 25 years
Community Member
What does the number of ports depend on? Two different AP 1121 with the same IOS version have different number of ports: the one has 8 and 6 has the other.
108
