BBSM5.3 not passing https/ssl traffic
We have deployed BBSM53 for guest auth on a wireless network. Regular 8080 traffic is flowing fine, but ssl/ipsec/443 traffic is being blocked. Authorizations are being done via access codes, so SSL was not a concern. Do you still have to have a SSL cert loaded on the BBSM to pass secure web traffic?
1 REPLY
Re: BBSM5.3 not passing https/ssl traffic
For reference, this was the fix that solved the issue.
Enable transparent proxy causes all traffic internally to the BBSM to
leave with a source address of the external address of the BBSM and a
port of 80. So when traffic that needs to go to the ssl/443 port leaves
the BBSM it is actually destined for port 80 due to transparent proxy
and the far ssl server drops the packet. Any data that needs a specific
port ( smtp/ftp/ssl/vpn ) will fail with transparent proxy.
You can disable transparent proxy and use nat externally to the bbsm for
the internal client network to get around this issue or use a public ip
space for your client network.
106
