Best performance config for a 4500
Being new to getting in the guts of a 4500 I have been advised that for the best performance the fiber ports in my wiring closet should be matched up by ip address on the 4500 fiber ports. That is the 4500 should know the ip address of the switch that is in the remote wiring closet etc. And vice versa that remote switch should know what port it is connecting to. If this is true how does on set that up?
thanks
Gary
1 REPLY
Re: Best performance config for a 4500
You can configure the interface speed and duplex mode parameters to auto and allow the Catalyst 4500 series switch to negotiate the interface speed and duplex mode between interfaces.Refer URL
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a0080731453.html#wp1068207
95
