Webcast-Catalyst9k
Highlighted
Best tool for log correlation
What will be the best tool to use in order to better correlate log of Cisco devices such as Switches, Routers and ASA ?
Hi ,
there are few exist , you can use one of them according to your needs::
The open source log management tools are:
     OSSEC (ossec.net)  : an open source tool for  analysis of real-time log data from Unix systems, Windows servers and network devices.
KiwiSyslog Server
syslog-ng
  LogHound
  Log2timeline
  LogZilla
there may be other tools also exist ..
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
VIP Purple
Some time ago, the answer would be "Cisco MARS" ... ;-) Now I would recommend to look at Splunk: http://www.splunk.com
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
528
