BGP Loadbalancing
IS is possible to provide BGP load balancing when customer is taking one link from me and one from different service provider. Definately both links are of same Bandwidth. As customer wants to use both links simultaneously so is there any way to config my router so that the customer can only pull half of its data through my link.
1 REPLY
Re: BGP Loadbalancing
AFAIK you can do this if the customer has it own IP Addressing scheme being used in place.
For ASN you can make use of Private ASN which can be used based on the ASN availability on both the SPs side.
This document will throw some lite on how u can achieve the same..
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
regs
102
