bits/s in MIB
I need to collect from Cisco router interfaces value bits/s (Mbits/s or kbits/s).
Has Cisco in MIB this value?
Peter
Blue
Re: bits/s in MIB
Only in octets (bytes):
64-bit counters, for high speed (e.g. gbit) interfaces
ifMIB.ifMIBObjects.ifXTable.ifXEntry.ifHCInOctets
(.1.3.6.1.2.1.31.1.1.1.6)
ifMIB.ifMIBObjects.ifXTable.ifXEntry.ifHCOutOctets
(1.3.6.1.2.1.31.1.1.1.10)
OR
32-bit counters
interfaces.ifTable.ifEntry.ifInOctets
(.1.3.6.1.2.1.2.2.1.10)
interfaces.ifTable.ifEntry.ifOutOctets (.1.3.6.1.2.1.2.2.1.16) "are counts of the number of bytes output by the interface as shown in the show interfaces command"
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800b69ac.shtml
Re: bits/s in MIB
but .1.3.6.1.2.1.31.1.1.1.6
is "total number of octets received on the interface", it is not rate. I need rate.
For example, I have 20 Mbits/s bandwith from MPLS service provider, I need to check rate on interface of router connected to MPLS.
Peter
Silver
Re: bits/s in MIB
There is no OID for rate you have to caculate it yourself.
For half duplex port: 8 * DELTA_OCTETS * 100 / (DELTA_TIME * ifSpeed)
For full duplex port: 8 * DELTA_OCTETS * 100 / (DELTA_TIME * 2 * ifSpeed)
and if you want you can add stuff like preable and interframe gap to your calculations.
Cheers,
Michel
Re: bits/s in MIB
Ok, Thanks.
But command "show interface" shows 5 minute rate xx bits/sec.
How router do it if OID for rate not exists? Does router store a previous value ifOutOctets and ifInOctets and calculate ????
Peter
Silver
Re: bits/s in MIB
AFAIK that is exactly what it does.
Michel
Blue
Re: bits/s in MIB
Here're the formulae used by one of our reporting tools (32-bit counters here):
Bytes In ifInOctets
Bits In (ifInOctets*8.0)
Bytes Out (NVL((ifInOctets + ifOutOctets),0)-NVL(ifInOctets,0))
Bits Out ((NVL((ifInOctets + ifOutOctets),0)-NVL(ifInOctets,0))*8.0)
Like Michel mentioned, additional considerations are needed depending on how often you poll those OIDs and duplexity of the interfaces.
537
