Blunder made ! pls help !
illusion_rox
hi all. I was writing an EEM applet on IOS version of 12.4(20). Following is the applet
event manager applet backup
event cli pattern "backup" sync yes
action 1.0 syslog msg "done-111"
now as you can guess, i cant delete it. if i type
no event manager applet backup
it detects "backup" keyword and runs the applet instead of deleting it. I know i made a blunder here, how can i delete this applet ?
Pls guide me
Joe Clarke
You can configure the following to temporarily disable EEM policy execution:
event manager scheduler suspend
Then you can delete your policy. then configure the following to re-enable policy execution:
no event manager scheduler suspend
yjdabear
In case you didn't "copy run start" after configuring the applet, "configure replace nvram:startup-config force" may be an option to overwrite the running-config with the startup config.
You mean i cant delete it now ????
Joe Clarke
Thanks alot sir, it worked :-)
