BRIDGE-MIB and Catalyst 4506
I am working with a Catalyst 4506, IOS 12.2(25)SG, and it seems that the BRIDGE-MIB isn't working. Any pointers on how I might be able to get the CAM info from this switch using SNMP.
Barry.
Silver
Re: BRIDGE-MIB and Catalyst 4506
What OID's did you try?
Do any other mibs work right?
Try this link for info
http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_tech_note09186a0080094a9b.shtml
Cheers,
Michel
I am trying to do basically what is outlined in the cisco document "How to Get Dynamic CAM Entries (CAM Table) for Catalyst Switches using SNMP" (Document ID: 13492) but walking dot1dTpFDbStatus returns "No Such Instance currently exists at this OID". I am successfully doing a bunch of other SNMP related "things".
a walk of BRIDGE-MIB::dot1dBridge returns:
snmpwalk -v1 -cpublic BRIDGE-MIB::dot1dBridge
BRIDGE-MIB::dot1dBaseBridgeAddress.0 = Hex-STRING: 00 15 62 A4 94 40
BRIDGE-MIB::dot1dBaseNumPorts.0 = INTEGER: 0
BRIDGE-MIB::dot1dBaseType.0 = INTEGER: transparent-only(2)
BRIDGE-MIB::dot1dTpLearnedEntryDiscards.0 = Counter32: 0
BRIDGE-MIB::dot1dTpAgingTime.0 = INTEGER: 300
Make sure you have it case sensitive (dot1dTpFdbStatus) rather than it is above.
Also, if you use community string indexing and a value other than the default (vlan1) do you get any results?
My bad,
It is working correctly. When I specify the community string indexing properly it works. I was expecting results from the default vlan and when I got none I assumed the mib wasn't working correctly. Once again, thanks everyone for your guidance and patience.
Barry.
455
