C6509 SNMP
Hi.
My CIO ask me about which type of snmp alarms and alerts the C6509 work. What he wants know?
My CIO want use WhatsUp Pro to management the C6509.
jreekers
Level 4
Level 4
What I would recommend is that you send an email to mii@external.cisco.com with the subject line of "help" (without the quotation marks). That will get you started with determining what MIBs are supported on the c6509 with whatever image you're running on that device.
Once you have that information, you can browse those particular MIB's to see what objects are supported.
This should get you started.
-J
You're welcome, and please, once you've reviewed that information, if you have any further questions...please ask. We'll be happy to help.
-J
David Stanford
This link will give you description of the traps (alarms) that can be sent without reading through all MIBs:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008021de3e.shtml
