C7200 console port failure
Hi All,
Does anyone have problem with Console port in C7200. When connecting console cable to console port and nothing happened. It is sure that right cable and correct port is connected. It is 3rd C7200 i have this problem.
Huong
Re: C7200 console port failure
I feel ur using DB-25 connector to get connected to ur console port,if thats the case i would better suggest to try with other connector but if u have already done with the that then better check out the console port settings.
regds
so the console access works with the same terminal software, cable and settings for another cisco router? I would use a different cable and connector because you might just have a broken wire or something like that.
Can you post the console section of your 7200 config to see what might be wrong there?
Martin
THanks a lot for your reply. Cable and terminal software are 101% sure no problem as i used the same cable and the same terminal software to connnect to another cisco and it works well. Here is config for my console:
line con 0
password xxxxxxxxx
login
Huong
You do not get any prompt or output even when hitting return for serveral times?
Can you also post a show version, namely the setting of your config-register. This has an impact on console speed settings as well.
Hope this helps
Martin
Thanks a lot for yout reply. I dont get any output. Below is show version:
sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(13)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Nov-02 23:39 by ccai
Image text-base: 0x60008940, data-base: 0x61A28000
ROM: System Bootstrap, Version 12.2(4r)B, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.2(11)T, RELEASE SOFTWARE (fc1)
RTR7206 uptime is 16 weeks, 2 days, 19 hours, 46 minutes
System restarted at 22:40:20 GMT Mon Sep 12 2005
System image file is "disk0:c7200-is-mz.122-13.T.bin"
cisco 7206VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memory.
Processor board ID 26819920
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.6
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
OK,
from what you have shown I would conclude NO configuration problem on the router. So your connector, cable, terminal program/laptop OR the console port can be the reason.
Hope this helps
Martin
Thanks a lot for your reply. I suspect that console port failure.
Huong
201
