07-30-2012 05:27 AM
Hi Guys,
I have installed LMS 4.1 and discover all the devices (router/switches) but i want to show IP Phone on the LMS. I am unable to discover call manager in LMS 4.1 topology.
In Call Manager 8.6 in Cisco Serviceability under snmp setting i have enable the read community string and check snmp, MIB service are running.
AM i using the correct proecdure. How can i get the Call Manager on LMS server so that i can see IP phones on LMS topology.
8.6 is installed on VM Ware.
Looking for your reply.
Need urgent Help
Thanks in advance.
07-31-2012 03:45 AM
Looking for replies in the above issue..Have to solve ASAP.
07-31-2012 03:53 AM
Just replied on :
https://supportforums.cisco.com/thread/2162934
Along with SNMP process, the Call Manager process should also be running.
You can check if the snmp is reachable from LMS server, do a snmpwalk on CUCM either from Device Centre or you can do is from NMSROOT/objects/jt/bin/snmpwalk.
Syntax:
NMSROOT/Objects/jt/bin>snmpwalk -v
Example:
NMSROOT/Objects/jt/bin>snmpwalk -v 2c -c public 10.10.10.1 .1.3.6.1.2.1.1
-Thanks
03-26-2013 01:27 AM
Facing the same problem
with LMS 4.2.2
have you solve it fazal from tera
this is zaher
03-26-2013 02:40 AM
Hi Zaher,
you have to add Call Manager server in the the LMS and add the SNMP details for LMS server details in the call manager, as far as i remember its in serviceability. Check once.
You will get the result as shown in attached images.
