Webcast-Catalyst9k
Campus 3.3 Discovery
Server Configuration> Administration> Stop Process > .
Is there a process I can stop that will kill the discovery process from the GUI?
See the attached screen print..
1 ACCEPTED SOLUTION
Re: Campus 3.3 Discovery
You shouldn't kill the discovery once it is started. If you do it can lead to CM database corruption.
The process which handles discovery in LMS 2.2 (CM 3.3) is ANIServer. However, I would suggest waiting for it to complete instead of killing it.
1 REPLY
138
