Campus Manager 3.3
I must be missing something here - how do you update the logical and physical discrepancy reports in Campus Manager? For example, it is reporting that a trunk port is running spanning-tree portfast. It most likely was at one time but has since been fixed yet it is still reporting this issue. Isn't there a way to acknowledge an issue so that it is no longer reported once it has been fixed.
Any thoughts are appreciated. David
Red
Re: Campus Manager 3.3
These are evaluated any time a major discovery runs.
There is no way to acknowledge or clear them.
If they still show up after discoveries, then there could be three reasons that I can think of:
- the discrepancy is indeed still there
- the database is corrupt, and you'll need a re-init
- this is some kind of a bug
Thanks for your thoughts. I appreciate it. David
105
