Campus Manager 4.0.3 neighbours
Why when I run device discovery in Campus Manager 4.0.3 I discover all switches on my network (which I want). These also have the correct neighbours assigned.
But when I run Campus data collect afterwards so that I can use these in topology map Distribution switches dont have any neighbours. I have modified Seeds, IP ranges, and SNMP on the switches. I have even purged the databases incase there was corruption while the database was installed.
The network is quite simple with Core -> Dist Layer3, Dist-> Access Layer2.
Does anyone know a resolution so that I can have the correct links\neighbours with the devices for Topology View?
1 REPLY
Re: Campus Manager 4.0.3 neighbours
check out the following link for troubleshooting when devices are not discovered :
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#topic2
93
