Community Member
Campus Manager - Ciscowierdyworks
Hi everyone,
This is wierd, campus manager is reporting a device is on a switch port, but the switchport has been shutdown for a long time.
00-08-02-8a-0c-03 pc123.core.local 10.50.170.202 10.50.168.0/21 <device> Fa0/10 XP_Client_LAN_2 30 Aug 2007, 13:49:40 BST
<device>#sh mac-address-table address 0008.028a.0c03
Non-static Address Table:
Destination Address Address Type VLAN Destination Port
0008.028a.0c03 Secure 24 FastEthernet0/10
<device>#sh int fas 0/10
FastEthernet0/10 is administratively down, line protocol is down
<device>#sho int fa0/10
Hardware is Fast Ethernet, address is 0007.0ed7.e24a (bia 0007.0ed7.e24a)
Description: 1/G/2/136
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 40w1d, output hang never
Last clearing of "show interface" counters 4w6d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
0 packets output, 0 bytes, 0 underruns
0 lost carrier, 0 no carrier
CW2K versions:
CiscoWorks Common Services 3.0.5
Campus Manager 4.0.6 12
Device Fault Manager 2.0.8
Resource Manager Essentials 4.0.5
Any thoughts appreciated on why this is being reported.
Kind regards
Re: Campus Manager - Ciscowierdyworks
What type of switch is this? Looks to be more of a switch issue than UT. If the MAC is showing up in the cam table then UT will put it in its reports. From the output above it looks like it is showing in the MAC/CAM tables.
Does show cam dynamic show this MAC?
Community Member
Hi, thanks for replying.
The switch is an IOS switch cisco WS-C3548-XL running 12.0(5)WC2 (old IOS I know), however, the IOS equivalent of the command above is as follows:
TOR-I-SWT006#sho mac-address-table int fa0/10
...and the address type is secure, meaning its a manually static configured MAC address assigned to that switchport, so although the switchport is admin down why and how is campus manager reporting and resolving the mac address to the device name?
I think it was because the switchport was enabled at some point and campus manager has cached this info???
I know campus manager can be network intensive when UT is enabled, is there a tuning guide for UT and campus manager? What do people typically set their UT and campus manager polling times to?
kind regards
103
