02-07-2007 02:31 PM
HI,
Campus Manager keeps reporting BPDU-Guard and BPDU Filter as being disabled on the access ports of all of my 2950s, when in fact is is enabled. I've tried global and port configs on the switches.
I've reset those physical discrepancy settings( checked them on and off)in LMS, then re-ran data collection. No change.
Doing a show spanning tree summary shows that in fact these options are enabled.
Any ideas?
Michael
Type BPDU-Guard disabled on access ports
Severity High
First found 2007/02/07 13:29:06
Description :
[asw-annex1],Fa0/1-24
asw-annex1 has the following access ports with BPDU-Guard disabled
PortFast disabled ports:
Port Fa0/1
Port Fa0/2
Port Fa0/3
Port Fa0/4
Port Fa0/5
Port Fa0/6
Port Fa0/7
Port Fa0/8
Port Fa0/9
Port Fa0/10
Port Fa0/11
Port Fa0/12
Port Fa0/13
Port Fa0/14
Port Fa0/15
Port Fa0/16
Port Fa0/17
Port Fa0/18
Port Fa0/19
Port Fa0/20
Port Fa0/21
Port Fa0/22
Port Fa0/23
Port Fa0/24
02-07-2007 11:31 PM
This is known bug (CSCsg01956). The workaround is to either ignore the discrepancy for your 2950s, or disable it altogether.
02-08-2007 08:22 AM
Hey thanks a bunch. I keep forgetting to check the known bugs.
mlc
