Webcast-Catalyst9k
Campus Manager Topology Map
Hi all,
I am trying to get a topology map of my network with Campus Manager but the Topology map does not show the serial links between the routers, is the campus manager topology map able to display serial links between routers?
1 ACCEPTED SOLUTION
Re: Campus Manager Topology Map
CDP must be explicitly enabled on multi-point links with the "cdp enable" command.
Yes, provided CDP is running on both ends of each link, and each router sees the other as its CDP neighbor (i.e. in the output of "show cdp neighbor").
Hi Joe,
Thans for the reply, and you are right, I can olny see the serial links that appera on the cdp neigh table. I have some multipoint serial links that even with cdp running globally I am not able to see them in the map, do you know if there is something I can do to see these multipoint links?
thanks!
308
