Campus Manager topology.
I am having two routers added in the Campus Manager. It shows me a single serial connection between them but i am having two serial links between them.
So is it possible for the CM to shows both the links.
regards,
Pulkit
Silver
Re: Campus Manager topology.
Is CDP active on both links? Do the devices show up twice in the "sh cdp neig"
If you hover the link in campus or select its attributes does it only mention one of the links?
Cheers,
Michel
Yes CDP is active in both the links.
When i check sh CDP neighb detail in router it shows the same neighbor twice,
Silver
With the "sho cdp nei det" does the "interface" section show the same remote device interface for both entries ?
Do you specify the CDP source in your device configurations ?
135
