10-26-2010 06:37 AM
I wonder if anyone can help, I have 7 Cisco 3750s that as soon as the Data Collection Schedule kicks in, every 4 hours, SNMP stops on the switches. The switches are still available on the network however Fault Manager and our separate SNMP monitoring tool flag up the issue.
I have other 3750 switches with the same IOS on them and they are not affected.
Has anyone seen this before?
Thanks in advance,
David.
10-31-2010 09:48 AM
When this problem occurs, you need to capture the output of "show stack PID" from a switch where PID is the process ID of the SNMP ENGINE and IP SNMP processes. You may need to run these commands a few times in quick succession while the problem is occurring. Post the output as well as the show version from the switch.
11-16-2010 08:22 AM
Hi there,
Thanks for that d sorry for the late reply, I have been on holiday. Here is the output from sh stack PID
#sh stack 253
Process 253: IP SNMP
Stack segment 0x407A8B0 - 0x407D790
FP: 0x407D6C0, RA: 0x1254EE4
FP: 0x407D780, RA: 0xA6B34
FP: 0x407D788, RA: 0x941AF0
FP: 0x0, RA: 0x9387B8
#sh stack 253
#sh stack 253
#sh stack 255
Process 255: SNMP ENGINE
Stack segment 0x40806C8 - 0x40835A8
FP: 0x40831E8, RA: 0x1254EE4
FP: 0x4083220, RA: 0x51FC70
FP: 0x4083238, RA: 0x58AFB4
FP: 0x4083260, RA: 0x58B1B8
FP: 0x4083340, RA: 0x587E7C
FP: 0x4083360, RA: 0x5893F4
FP: 0x4083380, RA: 0x58978C
FP: 0x4083388, RA: 0x41D904
FP: 0x40833A0, RA: 0x94642C
FP: 0x40833B0, RA: 0x946584
FP: 0x40833C8, RA: 0x9468F8
FP: 0x40833D0, RA: 0x41D364
FP: 0x40833F0, RA: 0x117D5C0
FP: 0x4083428, RA: 0x117BDBC
FP: 0x4083470, RA: 0x115EAB0
FP: 0x40834D8, RA: 0x1135D78
FP: 0x4083540, RA: 0x1128B1C
FP: 0x4083598, RA: 0x114FFCC
FP: 0x40835A0, RA: 0x941AF0
#sh stack 255
I have also attached the switch config.
I really appreciate your hep with this.
David.
11-17-2010 11:14 PM
I need the show ver from this switch to be able to decode the stack.
11-18-2010 01:00 AM
11-18-2010 10:43 PM
This looks like CSCsz89393. If switch stacks contain more than four high-capacity switches, SNMP can be slow to respond. The fix is in 12.2(50)SE3 or 12.2(52)SE.
