Can Netflow collect statistics on layer2 interfaces?
I have enabled netflow on a 6513 running 12.2(33)SXH2a. Right now it is collecting statistics for layer3 interfaces only. Can Netflow be configured to collect statistics for layer2 interfaces?
Re: Can Netflow collect statistics on layer2 interfaces?
Nope.
Hope that helps.
Curious... what type of information are you trying to capture in netflow on a L2 interface?
I'm concerned about seeing server to server flows on the same subnet/vlan. Will a L3 vlan interface do the trick?
Hall of Fame Super Silver
Chris
If the server to server flows are on the same subnet/vlan then the servers communicate directly with each other - from a layer 3 perspective. (frames do come in one layer 2 switch port and exit another layer 2 switchport - so in a layer 2 perspective the 6500 does see them) From a layer 3 perspective the 6500 does not see that traffic. And NetFlow reflects what the router/switch sees at layer 3. So I do not believe that it is possible to see what you want with NetFlow.
Rick
Thanks Rick, That clears it up for me.
on a Cat6500 (Sup720) it is possible to monitor L2 traffic with netflow.
See http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/netflow.html#wp1157805 (Enabling NetFlow for Ingress-Bridged IP Traffic) for details.
279
