Can´t discover PIX 515E with LMS 3.2
rouven.heim
I try to discover our PIX 515E with LMS Device Discovery - without success. So how do I need to configure the PIX to be discovered by LMS?
We use the PIX Software Version 6.3(4).
Greetings,
Rouven
Michel Hegeraat
Level 7
Level 7
Check if this pix and the software is in the supported devices list, and if it is, how do you try to reach it?
Does it respond to SNMP? It must.
Did you add it as a seed device? Could help.
If you use the CDP module your device you wish to discover should talk CDP. Does it?
if you use ping sweep it should respond to ICMP. Does it?
Cheers,
Michel
