Can't start LMS3.2 Daemon on Window 2008
I've installed LMS3.2 on Window Server 2008
but CiscoWorks Daemon can't be started.
C:\Users\Administrator>net start crmdmgtd
The service is not responding to the control function.
More help is available by typing NET HELPMSG 2186.
I've tried install on Window Server 2003 and it's work.
Do I need to set anythings on Window 2008?
Thank.
1 ACCEPTED SOLUTION
Re: Can't start LMS3.2 Daemon on Window 2008
The problem is with the way Windows 2008 handles swap. Go to the System control panel > Advanced Settings. Click the Settings button under Performance, and select the Advanced tab. Click the change button. Select Custom Size. Add at least a minimum of 2048 MB and a max of 4095 MB, and click Set. Apply the changes, then reboot, and LMS will start.
Problem is solved.
Thank you jclarke
What kind of license are we talking about here? 1500 user license server needs 4gb of ram with 8gb swap.
300 license server needs 2gb of ram with 4gb swap?
I restarted my server with the swap settings above and it is still not starting thr daemon manager?
Windows 2008 SP2
Please start a new thread for your question.
Thank you for resolve the problem i can run lms 3.2 on windows 2008
746
