Looks like it uses "Common Services Software 2.2 with SP3". Can it get installed into the same CSCOpx directory as LMS 2.2 (CS 2.2 with SP2)? If not, can they still co-exist on the same server but in different $NMSROOT directories? Whatever the case, will it be an issue later on when upgrading LMS to 2.5? Any way to keep both VMS 2.3 and LMS 2.5 running on the same box?
