can we get IP phones serial number with LMS ?
I have to get all the serial numbers of my IP phones linked to IP phone type and IP phone location.
Does a report (end host or other)exist to answer this need ?
If another solution exists, I take too.
Re: can we get IP phones serial number with LMS ?
LMS does not provide serial number information from IP phones since they are not SNMP-manageable. I also checked the CISCO-CCM-MIB, and I could not find any objects that the Call Managers expose to get phone serial numbers. There may be a way to get this information via XML from the CCM, but I am not sure.
I guess that depends on how you set it up.
Bare with me as I didn't set ours up however;
I can obtain IP Phone serial numbers in user tracking by looking in the "Phone Desc" column. SEPxxxxxxxxx
If not mistaken, U can only capture MAC address from CCM, such as SEPXXXXXXXX, but not serial number.
I wonder what is the best way to gather the serial number for 1300 units of IP Phone, any idea?
I am new to Call Manager.
But I have found you can http to IP Phones and see the S/N.
Not sure what the best way to get all S/N's would be, but maybe some others will have ideas.
Good Luck
There is no way from LMS and not even from Unified Operation Manager - UCOM .. I searched many locations try to find the DB schema for the CCM as it must be thee somewhere but no luck yet , i ended up doing it manually for 1K phones .. I regret I didnt handheld scan it .
650
