capture memory
Hi frenz,
Can i increase capture buffer memory.i.e i wanna to see many capture at a time so i need it. Can i do this? if yes than how?
1 ACCEPTED SOLUTION
Re: capture memory
Sorry, I was mistaken. All of our NAMs had been upgraded to 3.5, but I thought I was looking at a 3.4 NAM. The capture direct to disk is only in NAM 3.5.
Re: capture memory
To what product do you refer?
Re: capture memory
Hi clarke,
I am referrig NAM2-3.4...
Re: capture memory
The NAM2 has a memory limit of 300 MB for capture buffers. This cannot be increased. However, NAM 3.4 and higher can do a capture to disk. You have about 400 MB of local NAM disk space which you can use for packet captures.
If you upgrade to NAM 3.5, you can make use of NFS mounts and iSCSI drives for additional capture space.
Re: capture memory
Hi clarke, As I have NAM 3.4. So i can do capture to disk. So can u tell me how can i do this?
thanks
Re: capture memory
129
