Webcast-Catalyst9k
CAR
Router(config-if)# rate-limit {input | output} [access-group [rate-limit] acl-index] bps burst-normal burst-max conform-action action exceed-action action
is the sytax for configuration of the CAR on an Interface
What is mean by Burst normal and Burst Max
Can any one Help on this
Bronze
Re: CAR
You can have a three level form of ratelimiting with normal rate, normal burst, then max burst. Best way to do the ratelimit would be to set the normal and max burst to the same, but follow the formula of:
(normal rate * 1.5)/8
So, if you wanted to rate limit somebody to 2Mbps in both directions, the config on the interface would look like this:
rate-limit input 2048000 384000 384000 conform-action transmit exceed-action drop
rate-limit output 2048000 384000 384000 conform-action transmit exceed-action drop
Hope this helps.
Re: CAR
sean what this formula is about.
what is burstrate
Bronze
Re: CAR
The burst rate is the ammount of traffic that can be sent per second (this dictates the number of smaller burst per second to try and level traffic flow). Hope this helps.
109
