Cat 3750 and EEM
HI,
I have a 3750 as below and it doesnt seem to have eem commands on it.
I thought EEM was supported for this platform,IOS version and Package level?
Any Ideas?
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
System image file is "flash:c3750-ipbasek9-mz.122-53.SE2.bin"
Re: Cat 3750 and EEM
Yes, EEM should be supported on that image.  To confirm, does the switch support "show event manager version"?
Thanks Joe no 'show event manager version' is not available or any 'event' command
I did use the feature navigator before posting the question and it does look like it is supported
alright and in the base package aswell..
All I can think of is that the user does not have priv 15... customer is using tacacs aswell..
Is there anything else i could check to confirm...
Some output below
#e?
enable  eou  erase  exit
#show e?
eap        eigrp  energywise  env
eou        epm    errdisable  etherchannel
exception
#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
(config)#e?
eap   enable  end         energywise
eou   epm     errdisable  exception
exit
It could be something to do with privilege.  I don't have a 3750 running that image, but EEM really should be there.  The source code seems to agree.
Bronze
     You need to be running a IP Services feature set for EEM. The IOS level is fine, just change the feature set.
- VR
Actually, EEM is in IPBASE, but it is EEMLite.  EEMLite is a stripped down version of EEM designed for consumption only by the Auto Smart Ports feature.  While the subsystems and processes are there, the CLI to configure EEM has been omitted.  Instead, the ASP feature configures EEM via an internal API.  This was done on Cat2k switches in the LAN BASE images and Cat3k switches in IPBASE.
Admittedly, the Feature Navigator needs to be fixed as this is very confusing.  True user-consumable EEM is not available unless you are running IPSERVICES.
Is this definitely not a defect that the CLI commands are disabled?
I have the same issue and when i look at the processes i get this:
#show process | inc EEM
   9 Mwe  1CF14D8          49       971      50  7708/9000    0 EEM ED Syslog
  57 Mwe  1CD7DB0      286447   1855661     154  7700/9000    0 EEM ED ND
  58 Mwe  1CC7330           0       187       0  7676/9000    0 EEM ED Identity
  59 Mwe  1CC7330           0       333       0  7668/9000    0 EEM ED MAT
282 Mwe  1CDE97C           0         2       0  7852/9000    0 EEM ED Routing
288 Mwe  1C82058           9        53     169  4556/6000    0 EEM Server
289 Mwe  1CA2888           0         2       0  5100/6000    0 EEM Policy Direc
291 Mwe  1CC7330           0         2       0  7820/9000    0 EEM ED CLI
292 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED Counter
293 Mwe  1CC7330           0         3       0  7820/9000    0 EEM ED Interface
294 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED IOSWD
295 Mwe  1CC7330           0         3       0  7820/9000    0 EEM ED None
296 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED OIR
298 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED SNMP
299 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED SNMP Obje
300 Mwe  1CC7330           0         3       0  7824/9000    0 EEM ED Ipsla
301 Mwe  1CEE868           0         2       0  7856/9000    0 EEM ED SNMP Noti
302 Mwe  1CC7330       11653    150780      77  7624/9000    0 EEM ED Timer
Looks like all the event detector processes are running and getting invoked. The syslog one has been invoked 971 times for example.
Does the auto smart ports feature use all of these? Also the policies are for eem 3.2 not eem 2.4 which is what is in the feature navigator. Would be really nice to be able to have cli access to these processes seeing as they are running.
No, this is not a platform defect.  This is by design.  IPBASE does not have the CLI hooks to configure EEM.  I am trying to get Feature Navigator fixed to relfect proper data.
The ED processes will be running, but will not invoke policies unless ASP macros are defined and enabled.  The EEMLite subsystem includes all of the EEM 3.2 EDs, but ASP typically uses neighbor discovery, MAC address notification, and identiy.
1265
