Catalyst 3750 - ENTITY-MIB does not return contextName in entLogicalTable
I have a Catalyst 3750 switch running IOS version 12.2(25)SEE4. SNMP v3 users, groups and views have been configured. "show snmp context" shows contexts per VLAN. Querying the entLogicalTable in ENTITY-MIB returns the list of contexts, but the entLogicalContextName field is blank for all contexts.
I also added the following config to my SNMP view to see if Secure SNMP views was causing the problem, but no luck.
snmp-server view myview entityLogical included
snmp-server view myview entLogicalEntry.8 included
Any ideas? My other Cat3750 running IOS version 12.2(35)SE works just fine and returns the right contextNames. Is this a known problem?
Thanks in advance,
Venkat
1 ACCEPTED SOLUTION
Re: Catalyst 3750 - ENTITY-MIB does not return contextName in en
This is bug CSCsg04264. It is fixed in 12.2(35)SE code.
1 REPLY
163
