Catalyst 4507R plus E can't exract inventory from LMS 4.1
L1GHTSPEED
We have 694 units Cisco Catalyst 4507R plus E swithes accross the network. LMS 4.1 can discover it no problem however, i cannot extract inventory information for these switches. I get the this "Number of devices that do not have inventory collected data" on the report.
installed System image file is "bootflash:cat4500e-entservicesk9-mz.150-2.SG1.bin"
i saw this supported version:
150-1.XO (or) 03.01.00.SG <<--- should i have the exact image or higher version will do?
[Inventory Config and Image Management]
reference: http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html
is the image installed on my switches not supported? seems like I have higher version. Any idea?
Marvin Rhoads
A newer version of IOS should generally be fine.
It's generally the SNMP sysObjectID that LSM keys into. As noted in the table you cited, it should be 1.3.6.1.4.1.9.1.1286 for the 4507R+E.
Can u specify that higher IOS version that does the job? thanks!
Perhaps my reply was unclear. Let me restate - The versions in the device support table should be considreed MINIMUM versions. Any later (higher number) version shoud be OK,
