Catalyst 6500 Temp
Is the temperature around 32 °C is acceptable inside a cabinet that hosts 6513 switch?
Since the data sheet for the catalyst 6500 is saying that the max. temp. is 40 °C when a device in operating mode.
Core_D#show environment temperature
VTT 1 outlet temperature: 33C
VTT 2 outlet temperature: 35C
VTT 3 outlet temperature: 35C
module 2 outlet1 temperature: 40C
module 2 outlet2 temperature: 43C
module 3 outlet temperature: 41C
module 3 inlet temperature: 30C
module 3 device-1 temperature: 31C
module 3 device-2 temperature: 36C
module 4 outlet temperature: 40C
module 4 inlet temperature: 35C
module 4 device-1 temperature: 31C
module 4 device-2 temperature: 36C
module 7 outlet temperature: 36C
module 7 inlet temperature: 31C
module 7 device-1 temperature: 41C
module 7 device-2 temperature: 42C
module 7 asic-1 temperature: 31C
module 7 asic-2 temperature: 31C
module 7 asic-3 temperature: 31C
module 7 asic-4 temperature: 31C
module 7 asic-5 temperature: 31C
module 7 asic-6 temperature: 31C
module 7 RP outlet temperature: 35C
module 7 RP inlet temperature: 34C
module 7 EARL outlet temperature: 42C
module 7 EARL inlet temperature: 29C
module 9 outlet temperature: 58C
module 9 inlet temperature: 31C
module 13 outlet temperature: 48C
module 13 inlet temperature: 30C
Thanks in advance
Abd Alqader
Community Member
Re: Catalyst 6500 Temp
Yes, 32 °C is acceptable. It will not effect in its working function.
