Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Blue
CatOS CLI equivalent of what Mini-RMON manager does
I assume the Mini-RMON manager in CiscoView is using snmpsets to configure the RMON on CatOS, but I haven't found any documentation on what exactly are getting set, except "set snmp rmon" and some of the possible MIB OIDs, unlike the aplentyful info on what can be done on IOS. I assume the RMON settings will be saved in the running-config in clear text. Such info would be come in handy, because Mini-RMON manager appears to be able to configure only one device at a time.
1 ACCEPTED SOLUTION
Re: CatOS CLI equivalent of what Mini-RMON manager does
There is no CLI interface for mini-RMON in CatOS. Everything the CiscoView mini-RMON manager does is via SNMP using the RMON-MIB.
Here's a document illustrating how RMON events and alarms can be configured using SNMP:
http://www.cisco.com/en/US/tech/tk961/technologies_configuration_example09186a0080093e96.shtml
The same general principle applies to configuring stats and histories. You could also sniff the traffic the mini-RMON manager sends to the device to get an idea of how configuration is done.
1 REPLY
114
