11-03-2006 12:23 AM
I have to test VoIP/Video over 3640[IOS release 12.4(1a)] router with a NM-16ESW card.I have already made voip/video run over it, now i want to implement QoS using CBWFQ.From the documentation of this interface I found that it supports:
"Port-Based Reclassification for Queues on Each 10/100 That Are Configurable Using a Weighted Round Robin (WRR) Scheduler".
Since it says WRR & not CBWFQ clearly, im not sure whether it will work or not.
pls guide.
Saif.
11-03-2006 01:59 AM
Hi Saif,
As you have mentioned , the ESW card supports QOS ( L2 QOS ) where you cannot define the queues as done by CBWFQ , but you can utilise the available four Queues on
the L2 engine of the router .
Traffic is sent on the four queues based on the COS value being set or from the cos value recieved from the Ip phone .
You can look at this document , but requires privilege login
hope it helps
regards
vanesh k
11-03-2006 06:50 AM
Thanx.but i don have the privilaged login.
secondly i must mention here that i used no switchport command to make it work as router, i mean IP address can be configured now on it.
regards
saif
11-03-2006 09:03 AM
Hi saif,
If you have made it as a router port and assigned ip , then try configuring CBWFQ .
give me ur mail id so that I can forward a doc to u.
regards
vanesh k
11-03-2006 09:17 AM
11-03-2006 09:40 AM
Hi saif,
pls go through the QOS part and it has explantations abt L2 qos
regards
vanesh k
