CE 500 on LMS 3.0
Could you plz help me in having the new cisco switches Ce 500 TT and LC series on the LMS 3.0?
I didn't find it in the supported devices for the 3.0, but is there any work around?
  • Network Management
1 ACCEPTED SOLUTION
Re: CE 500 on LMS 3.0
These switches are not supported by LMS, and there is no plan to add support for them. The intended management application for the CE switches in Cisco config Assistant (CCA). CCA can be downloaded from http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281010085 .
1 REPLY
120
