01-12-2012 09:06 AM
Hi all, I'm putting feelers out there to see if there's a way to configure a SPAN session with the monitor "port" being on a totally different subnet (across a WAN if you will). Essentially I'd like to be able to have a wireshark terminal(s) set up in our data center and be able to configure a port on a remote site to push to it. This would alleviate the need to go on-site to either configure a PC or add a PC to troubleshoot.
Thanks in advance all!
01-12-2012 11:38 AM
Yes - in a limited fashion. it's called rspan and requires switch infrastructure that supports it. Please see this Cisco document for more info and this one for specific information.
01-12-2012 11:44 AM
Thanks Marvin, I'll check out those docs. I was under the impression that RSPAN was limited to an infrastructure that shared a common layer 3 gateway and could not traverse a routed boundary (i.e. a WAN or multi-hop destination). I'll look into that.
01-12-2012 12:13 PM
Right - there are limitations. You cannot nor should you want to span/rspan traffic to far. Intervening links could easily be overwhelmed / broken if this were possible.
