Change Authenticaion Protocol for RADUIS communication.
can you change the authentication protocol on the router to use any other method then PAP to a RADUIS server (ACS)for administration access?
1 REPLY
Silver
Re: Change Authenticaion Protocol for RADUIS communication.
I think ACS is able to work with chap, so you can use chap instead of pap. You can use "ppp authentication chap pap" command in case chap doesnot work, pap can be used.
101
