Changing Snmp community strings in 2955 Switch
Connected by telnet and having loged in with enable rights I am not able to change the community strings public ( for read-only) and private (for read-write). The message I get is this:
CIM_EGR_SW1>enable
Password:
CIM_EGR_SW1#set snmp community read-only example
% Invalid input detected at '^' marker.
CIM_EGR_SW1#
I think the sentence is right, and have repeated with other names. Also it is not possible to delete community public.
Could somebody help me?
Tanks!
Hall of Fame Super Silver
Re: Changing Snmp community strings in 2955 Switch
The correct syntax is:
snmp-server community string [view view-name] [ro | rw] [access-list-number]
You must be in CONFIGURATION mode (conf t) to execute this command.
Also, from conf mode, to disable access for an SNMP community, set the community string for that community to the null string (do not enter a value for the community string).
Reference for this and more: http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swsnmp.htm#wp1026674
Thanks for your fast answer!. Do you know any product (free license) to manage this messages or traps comming from the switches?. My network have 18 switches and there is a workgroup of workstations connected.
Red
conf t
snmp-server community blah ro
snmp-server community blahblah rw
no snmp-server community public ro
124
