Changing the IP on Cisco Works LMS 2.5-UR-K9
I need to change the IP on my Server that have installed Cisco Works LMS 2.5-UR-K9.
I already do it, but when try to enter the LSM I can only get to the User and Password page, I can't get in.
If I return to the ols IP it works find.
Is there a special procedure to change the IP addresss of the Cisco Works Server??
I'll apreciate your comments.
Thanks!
1 ACCEPTED SOLUTION
Red
Re: Changing the IP on Cisco Works LMS 2.5-UR-K9
There is nothing special if all you do is change the ip address of the server. However, you have to make sure that you update your DNS (or whatever name resolution mechanism you are using).
For additional information:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/comser30/usrguide/diagnos.htm#wp1078369
1 REPLY
Red
98
